05-01-2020 03:31
05-01-2020 03:31
I have authorised the pairing of Fibit with Strava but when I go to export map and details to Strava from Fitbit only my text appears in Strava not the map. How can I get map into Strava?
05-02-2020
12:39
03:48
05-02-2020
12:39
03:48
@Nuala14-_ Welcome to the Community. I've moved your post to this board because it's related to the topic.
Thanks for letting me know that you've linked Fitbit and Strava. I would like you to take a look at this post, you'll learn more about the information that's going to sync between those apps.
When you export your Fitbit GPS data, you'll have to do it through a TCX file. This is why you're not seeing a map when exporting it. Check out this article.
I'll be around if you have any additional questions.
Best Answer05-03-2020 02:53
05-03-2020 02:53
Best Answer05-03-2020 07:13
05-03-2020 07:13
Normally after a user has connected Strava to their Fitbit account any activity recorded by Fitbit with GPS will get sent automatically to Strava.
