04-09-2024
07:15
08:52
EstuardoFitbit
04-09-2024
07:15
08:52
EstuardoFitbit
how do I get my Fitbit logged on to my Humana Go365
04-23-2024 07:51
04-23-2024 07:51
Thanks @pbkbrk a lot for sharing this information with us.
It's possible that the recent platform changes are causing the connection issues you're experiencing. Unfortunately, we don't have full visibility into other companies' internal updates, and therefore cannot offer a specific solution to resolve this type of problem.
However, I recommend contacting the other platform directly and inquiring about alternative ways to handle the situation. They may have implemented workarounds or solutions that we're unaware of.
04-09-2024 08:51
04-09-2024 08:51
Hello there @grandmacarol3, it is nice to see you around the neighborhood.
In this case, I suggest contacting them directly or checking out this help article I found on their website: How To Connect Fitbit.
04-17-2024 18:11
04-17-2024 18:11
I have chatted w/Humana, called Humana and called Google Fitbit. One of the tech people at Go365 did listen and uploaded directions for troubleshooting the sync. Still my Fitbit has not connected since Feb 23, 2024 so as to sync my steps. Yes, I can transfer my steps manually. Why in Feb? What changed between Humana Go365 and my Fitbit? I have read and reread the directions on the Humana website on how to remedy this issue. However, one problem still exists on my Fitbit dashboard online. Under my settings, there is no place to give permission for Go 365 for data access that I can see:
via Go365
“Find Third Party Apps or Data Permissions Locate Go365 and click”
Thanks I have been trying to resolve this problem since March 1.
Thanks for any additional tech help.
04-18-2024 07:22
04-18-2024 07:22
Hi there @ZZI welcome to the Community and thanks for mention that you have contact with Humana.
In this case, and considering what you mentioned, you can try disconnecting both apps from the Fitbit Dashboard. We actually have this option. Please follow these steps:
From here you will have access to the apps that are linked to your Fitbit account. You can revoke the access and then reconnect the apps again.
04-22-2024 05:34
04-22-2024 05:34
I found article that said Humana no longer will support Go365 for Commercial insurance after Feb 23,2024 but Medicare users would still be supported. This is when my data also stopped syncing. I am trying the disconnect from fitbit and the device in go365 and then reconnect and see how that goes for me. Not really expecting it to work but I can always hope.
04-23-2024 07:51
04-23-2024 07:51
