01-01-2014 14:42
01-01-2014 14:42
I purchased the lose it premium version so it would sync directly with my fitbit since it has the camera scanner capabilities and I have used it previously and am comfortable with the adding foods etc, however, I don't see how to import the data entered from loseit to fitbit-anyone with suggestions?
Thanks
Best Answer07-14-2014 08:59 - edited 07-14-2014 09:00
@tra You need to have Fitbit Premium membership. Use the fee trial and try to use the tab where it says export or food report. From there you can export food data. Or you can take a screenshot from your calorie records and print it. - I'm sorry that your post went without a response for so long.
