02-08-2019
16:43
07:52
AlejandraFitbit
02-08-2019
16:43
07:52
AlejandraFitbit
How do I link My Fitness Pal to Fitbit? It was linked with my old Fitbit Alta, but I can't figure out how to link it to my Charge 3. I know it must be simple. Can someone help?
Hi @Cscomoky in theory it should still be linked if you have not revoked the access.
The best way to check if its still linked is by signing into.your MFP App and going to settings and tapping on my My Apps & Devices and tapping on Fitbit Tracker where it will show if its still linked. If it needs linking again you can do it from there.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
02-10-2019
07:54
10:46
02-10-2019
07:54
10:46
Great to see you around @Cscomoky and @Tony.r thanks for the input.
I just wanted to let you know that I have moved your post from the Charge 3 board to the Third-Party Integrations board, since I think that here you will be able to see more related topics about this.
Regarding your inquiry, I agree with our friend. If you haven't revoked the access to MFP you don't need to link the accounts again. But you can always take a look at the help article How do I connect my Fitbit account with another app?.
Keep me posted. ![]()
Thanks, Tony and Alejandra! It worked itself out. I waited a while and it looks like it is linked. Sometimes I have trouble patiently waiting for my apps to sync!
@Cscomoky your welcome, at least its sorted now.
Tony | UK
03:02
10:45
02-13-2019
03:02
10:45
