10-19-2018
03:56
06:54
AlejandraFitbit
10-19-2018
03:56
06:54
AlejandraFitbit
I have Fitbit Versa and MyFitnessPal App. Where do I go on Versa to upload/sync with MyFitnessPal?
Best Answer@tckdavid1. You make the connection in the MFP app. Go to the hamburger icon (3 horizontal lines) in the upper corner and scroll down to Apps and Devices. Choose Fitbit there and follow the prompts.
In short, your versa wll not sync will then MFP, it is your Fitbit account that syncs.
10-21-2018
06:56
06:37
10-21-2018
06:56
06:37
Welcome to the Community @tckdavid1, @kcronin and @Rich_Laue thanks for stopping by.
I would like to know if you have linked your accounts? If you are having problems, you can follow the instructions provide in the help article How do I connect my Fitbit account with another app?.
Keep me posted. ![]()
Best AnswerHey, I cannot seem to link my Versa 2 to the my fitness pal app, it says not enough data provided or something along those lines. Any help would be appreciated. Thanks
Best AnswerOk @Noc36
You can not link your Versa to My fitness pal to need to link my fitness pal to you Fitbit account.
Let's go to the MFP page and tap on Connect.
You can also follow the instructions above.
If both fail, you will need to contact MFP, fitbit does not own or maintain this connection.
However if we have more info or a screen shot we may be able to give some guidance.
