How do I sync food entries from MyFitnessPal?
ANSWERED
How do I sync my food entries from Myfitness pal to my fitbit flex?
1 BEST ANSWER
Accepted Solutions
So Fitbit doesn't show under 'Your Apps'? If not, I'm guessing your accounts aren't actually connecting for some reason. Might be time to contact support if you've verified your account credentials are correct.
14 REPLIES 14
Log into MFP and goto: https://www.myfitnesspal.com/apps/show/30. 'Connect' the app and you should be good to go.
I have gone through both MFP and Fitbit to connect and they are still not syncing
Disconnect the apps, then connect from MFP to Fitbit. After connecting, you should see 'Fitbit Tracker' listed under 'Your Apps' on the http://www.myfitnesspal.com/apps page. After that, foods and activities should sync between the two apps.
Okay so call me dumb, but I cannot find where it gives me the "your apps" option. I have logged out of both and logged in and disconnected both (I think) but still nothing. Does it show the actual food in the log or does it just show the calories differences.
On the righthand side of the http://www.myfitnesspal.com/apps page, you should see a section labled 'Your Apps'. Under that section heading, you should see the app(s) that you have connected. For example, I have what's shown in the image below. The 'Fitbit Tracker' is what should show when you've connected MFP to Fitbit.
Entering foods in MFP once synced, will copy 'meal summaries' to your Fitbit dashboard (e.g. second image below). You'll see 'Fitbit calorie adjustments' in MFP based on activity that your Fitbit registers.
Okay see how your app states under it installed? Mine still continues to say connect. Any ideas?
It turns out it was an issue with MFP but it has all been corrected now. Thanks everyone for your help and advice.
how did you get MFP to connect with your fitbit.  I cannot get them to synch.
On the Fitbit website, you can link to My Fitness Pal here:  https://www.fitbit.com/apps/myfitnesspal
On the My Fitness Pal website, you can connect your Fitbit account here:  https://www.myfitnesspal.com/apps/show/30
I have done that.  But it still isn't synched up.  It shows under my Fit bit that I am allowing it to synch but nothing.  not sure what I am doing wrong.
it is not showing installed it shows connect still.  does that have anything to do with synching together?
Mine isn't working either
im having problems too trying to connect mfp with fitbit and its driving me insane in the fitbit apps area it says its connected i revoke it and go to mfp and press connect and give access but mfp doesnt say its installed but fitbit shows mfp inthe apps area dont know whats going on all the other apps connected to mfp work without a glitch
