07-15-2016 15:58
07-15-2016 15:58
I have already connected the apps but no ino is imported to fitbit. Now what?
Best Answer07-17-2016 05:05
07-17-2016 05:05
Welcome to the Community @magneto78. If your MFP account is not connecting with Fitbit. I recommend doing the following to re-link the accounts:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
I hope this helps, let me know the outcome. ![]()
Best Answer05-08-2020 18:12
05-08-2020 18:12
Hi there. I was wondering if we can see my weight recorded in MFP on Fitbit after linking apps? I want to export MFP recorded weight To Fitbit.....please let me know, thank you 🙂
