Hello!
I am wondering how the Withings scale integration is supposed to work. I linked my fitbit and Withings accounts and thought that from then on my weight as measured by the Withings scale would appear in the fitbit dashboard somehow. But it doesn't.
Is there something else I need to do? Or does it only get synced every 24 hours or something?
Thanks
TOA
16:04
07:50
03-23-2016
16:04
07:50
@TOA A warm welcome to the Community! You should connect your Withings scale to your Fitbit account. Please go here and follow the instructions to connect it.
The Aria scale syncs everytime you weight it in. So, I believe it's the same with Withings scale.
Hope this helps.
