12-20-2018
17:13
07:07
LanuzaFitbit
12-20-2018
17:13
07:07
LanuzaFitbit
how do you get it to sync with my fitness pal
Moderator edit: Clarified subject & Labels
Best Answer12-21-2018 07:06
12-21-2018 07:06
Hello @bkt101213.
I'll be happy to help you connect your Fitbit account to MFP.
Please try following these steps to connect them:
Let me know if you have any further questions.
Best Answer12-21-2018 13:32
12-21-2018 13:32
Best Answer12-25-2018 08:27
12-25-2018 08:27
Hello @bkt101213.
Thanks for getting back to me.
Could you share some screenshots of what you are seeing? I'd like to take a closer look at what you are seeing so that I can guide you through the process.
Best Answer12-29-2018 19:36
12-29-2018 19:36
a how to connect my fitbit to my fitness pal said go to computer and pick smartphone bit that's the problem I don't see any place to pick smartphone
Best Answer01-04-2019 10:56
01-04-2019 10:56
Hello @bkt101213.
I apologize for the delay in my response.
In that case I'd recommend trying to get in touch with them directly. They should definitely help you in order to be able to sync both apps.
