How to use Strava, MyFitnessPal and FitBit HR & avoid doubling?
ANSWERED
I'm not quite sure what is the right way to use my FitBit with Strava and MyFitnessPal.  I like Strava for tracking my runs using GPS on my phone and currently I start my run with Strava, then I also push the button on my HR to get it to track my activity.  My Strava and Fitbit accounts are linked and I also use MyFitnessPal
When I'm done it kind of looks like I have two different events logged in my dashboard.  Interestingly enough, neither says Strava.
I also have Strava and MyFitnessPal linked to each other.
I think I might have created some kind of weird circular loop with all these apps linking to each other.
Anyone using this combination of apps and can give me advise on the best way to set it up and use it?
1 BEST ANSWER
Accepted Solutions
It's great to have you here @farrsight! It's fun to use other third party applications to track your daily activities, however, it can be a bit confusing specially if you have them linked to each other. My recommendation is to log your activities using only one of the apps, in this case you can use Strava since you mentioned you use GPS for tracking and you can use MFP to log your food.
So you can have a better idea, this is how each one of the apps work:
MyFitnessPal
What syncs?
Fitbit > Steps > MFP
Fitbit > Calories > MFP
Fitbit > Aria measurements > MFP
MFP > Logged food > Fitbit
MFP > Activities > Fitbit
Strava
Log to this article for more information.
Let me know if you have any other questions. Robot Happy
Melissa | Community Moderator, Fitbit
How are you fitbitting with your (pet) best friend? Show us!
4 REPLIES 4
MyFitnessPal
What syncs?
Strava
Thanks  for this. So if I understand correctly. My best recipe for this combination of apps is:
Fitbit <---> My Fitness Pal (MFP)
Strava <---> Fitbit
And disconnect Strava from MFP so it doesn't double activities.
I assume any data from Strava that makes it into Fitibt will eventually funnel through to MFP?
Should work, though another route would be to skip the Strava<-->FitBit connection and use MFP as the conduit. Here's a really good article on this:
http://simon-willis.blogspot.ca/2015/03/keeping-cycling-data-in-sync-strava.html
Good luck!
That would be right @farrsight. What @zoinks recommends makes a lot of sense and it's an easier way to have all of your data registered in the correct apps and not get confused with how it shares the data.
I hope this helps for you. If you have any other questions or comments, feel free to post back. Smiley Happy
