09-09-2015 11:30
09-09-2015 11:30
Looks like at some point yesterday, anyone else seeing this, or is it just me? Tried disconnecting and it reconnects fine, but still isn't working.
09-11-2015
11:29
06:29
09-11-2015
11:29
06:29
Hey there @davidkmcw. It's great to see you in the Community! 🙂
What is it exactly that you or anyone else is being able to see? If you can please provide with as much detail as possible, I will be glad to help!
I'll be looking for your reply!
Best Answer09-13-2015 07:55
09-13-2015 07:55
08:06
06:28
09-13-2015
08:06
06:28
Hi there @Lancesmith34. It's great to have you in the Community!
I'll be honest with you, I just started using IFTTT and I think this is a great tool but I'm not very knowledgeable about it. From what I know, have you tried to remove the recipe and add it again and see if this fixes the problem?
Best Answer09-13-2015 08:18
09-13-2015 08:18
Best Answer09-13-2015 08:25
09-13-2015 08:25
Best Answer09-13-2015 08:47
09-13-2015 08:47
Got it @davidkmcw @Lancesmith34, I'll try to keep an eye on it and thanks for letting me know. I'll try to get in touch with the API team to see the progress on this!
Best Answer09-14-2015 09:49
09-14-2015 09:49
It has been 5 days since IFTTT has last had access to Fitbit. Running the check now I get the message "Something is wrong"
For now you can go here to find info to download the same data.
