05-10-2016 10:09
05-10-2016 10:09
Best Answer05-12-2016 05:14
05-12-2016 05:14
Hello @Nlb58, welcome aboard to our community. As long as you've linked Fitbit and MFP, you should see steps from Fitbit in MFP. Make sure in the MFP app you go to More > Steps > Select 'Fitbit Tracker' > go back and hit 'Sync' at the bottom. Your steps will show up in 'Diary' under the 'Exercise' section, along with a calorie adjustment calculated by MFP.
Since you already tried to relink your accounts please take a moment to reach out to our Support Team and let them know of your efforts to troubleshoot the issue and what you've already done. I have full faith that they will be able to advise you of the next steps after reviewing your device history with you.
Hope this helps and see you soon.
05-12-2016 05:14
Best Answer12-22-2016 06:42
12-22-2016 06:42
I tried your advice for syncing my Alta to mfp and it still didn't work. It didn't show up in my diary or under steps in the app. Please help. I am trying to refocus myself and this would help. Please help.
Best Answer12-24-2016 09:39
12-24-2016 09:39
Hey there @BrightStar85! Thanks for trying the procedure posted above. In order to make sure that your Fitbit is linked properly with MFP. Please go to your Dashboard > click on settings > applications> there you should see MyFitnessPal.
If you're not seeing it, then please follow these linking steps.
Hope this helps! Let me know how it goes.
Best Answer12-24-2016 14:04
