01-05-2022
12:47
17:09
LanuzaFitbit
01-05-2022
12:47
17:09
LanuzaFitbit
It is possible to see the activity tracked via FitBit in the LifeSum App. Unfortunately, it is not possible the other way round, It would be great if the tracked calories in LifeSum would be visible in the FitBit App/Dashboard. Not. necessarily all the single food, just the calories intake.
LifeSum is a lot easier to use for tracking food and a lot of people are asking for that feature. Please implement this.
Best Regards
Ulrikke
Moderator Edit: Labels
Best Answer01-06-2022 19:08
01-06-2022 19:08
Hello @Schnockf
I share the same opinion that Lifesum is an excellent nutrition tracker. However the missing communication (from Lifesum to Fitbit) is actually on Lifesum as the related API are made available from Fitbit. In the past I contacted Lifesum to have it implemented but got negative answer. You might try to do the same, maybe eventually they will implement it.
