I cannot import recent Map My Run activity even though I have the app synced with my Flex. I've disconnected and reconnect my device with the app several times. It has imported MMR activity from September 2014, but nothing newer including my run yesterday. I thought by connecting the Flex and the MMR app, the workouts would transfer from MMR to the Flex dashboard automatically. This is not the case. I've searched through the help documents and cannot find an answer to my problem and am a bit of a loss. To be clear, I have connected the device with the MMR app several times. Thanks for any insights.
@bdoylephotos It's great to have you here! Currently, MapMyRun data won't sync to Fitbit. Fitbit information will sync to MapMyRun.
If you're having any issue syncing Fitbit data to MapMyRun then just unlink and relink both accounts.
Hope this helps ![]()
