I've successfully connected a wyze scale to fitbit, but I'm trying to import about 6 months of past data to fitbit.
Have searched around extensively, and the Fitbit help center is of no use.
Has anyone ever pulled this off before? Is there a good third party app that I need to download in order to do it?
Best AnswerHello @negss I've moved your post to the Third Party App Board.
My thought is that if Wyze doesn't send the past readings, you may have to manually enter them.
You have a better chance of an answer here.
My experience is that an app that fails to sync, will send all past readings that failed once it reconnected. However if you recently connected for the first time, I'm not sure what should happen.
