11-29-2021
12:48
15:04
EdsonFitbit
11-29-2021
12:48
15:04
EdsonFitbit
Hey All - Has anyone been able to use the Charge 5 with the United Healthcare (UHC) Motion App? I know that the Charge 4 is compatible, and the UHC App itself doesn't list the Charge 5 yet (as of 11/29/2021).
If the Charge 5 doesn't support the Motion App natively, I thought I might be able to "trick" the app to think it's communicating with a Charge 4, if the Charge 5 provides the data required for the Motion App.
Thanks!
Best Answer09-23-2022 09:17
09-23-2022 09:17
Best Answer09-30-2022 04:04
09-30-2022 04:04
@MegaHertz60 Can you please help the OP in this thread?
Laurie | Maryland
Best Answer10-08-2022 15:28
10-08-2022 15:28
And now, after nearly a year since the original post, I am asking the same question. When will UHC Motion going to support the Charge 5???
12-02-2022 16:56
12-02-2022 16:56
I am also hoping this can be fixed! I literally purchased the Fitbit 5 THROUGH the UHC Motion app. Would be nice if there could be disclaimers on both ends. I have been a Fitbit user since the original charge HR. I debated the Apple Watch this go around and wanted to stick with my Fitbit. I seriously regret it and will stop recommending.
07-27-2023 05:26
07-27-2023 05:26
The disclaimer on both ends is an excellent point. When I got the Charge 5 I did not realize it would be an effective downgrade. Now it's not clear when I hit the milestones for UHC Motion until after the fact. If this is never addressed, I will not be getting any Fitbit/Google fitness trackers in the future ever again.
08-06-2023 14:45
08-06-2023 14:45
Same problem here. tab broke off. Got 1 replacement under warranty. Happened to the second one too, but that one wasn't under warranty. Got a different type band on Amazon that just surrounds the tracker. Works real well, and I can stick with using my 4.
Best Answer08-07-2023 07:23
08-07-2023 07:23
From experience the charge 5 will work with the UHC motion app, but it does not have an interface like the charge for on the watch, which is the biggest complaint. If Fitbit would only get that interface on the actual watch designed and installed, it would make it a big game changer. I went on many walks and have ended up a few steps short to reaching the goal for the day because you cannot tell if you're one step off or 100 steps from meeting the goal. Very unsatisfying about the charge 5. The charge for interface on the watch was much more user friendly, just poor band design which makes the charge 5 worth it if they would only put an interface on the actual watch
Best Answer08-07-2023 09:02
08-07-2023 09:02
