Is it possible to sync Weight Watchers with FitBit like My Fitness Pal can?
I've read on the forums that you can connect FitBit with My Fitness Pal, but I'm wondering if there is a way to connect it with the Weight Watchers tracking system? If not, I'd be curious to know if a future partnership is in the works.
2 REPLIES 2
It would be a great asset if we could sync the Weight Watchers with Fitbit.
What I did was just created a food called WW Points and gave them 50 cal per point. Then I look at my WW points and then add 1 point for each fruit I eat. For example. I eat 26 Point plus 10 Fruits/Veg then I would enter into Fitbit Log WW Points of 36 which is 1,800 Cals. For me it has be very accuarate; however, you may need to adjust how many Cal per Points you use.
I now put in 36 WW Points for the entire week then Fitbit App tells me if I am over or under which helps if I want to eat additional Points. Plus its easier to adjust WW Points in App too.
On the WW side, I only enter the number of steps for the day from FitBit and nothing else.
Hope this helps,
