10-26-2018 17:43
10-26-2018 17:43
Soooo I bought a new fitbit, the charge 3 and upon the initial set up it stated the power of vitality was down and unable to link at that time. I went on the website and it said I complete the registration but next step is to go back to my fitbit app to link the two. BUT WHERE. I look under applications and it's blank, I look under compatible apps and the vitality app isn't there. The dashboard is nothing but eat, drink, steps stuff. How does this work theres no instructions.
Best Answer10-28-2018 06:09
10-28-2018 06:09
Welcome to the Forums @Sheenak86.
Thanks for trying to connect them on your own before posting in here. Let me help you.
In order to connect Vitality to your Fibit account you need to follow these steps"
That should do trick and get you to connect and get all of the information to sync over.
Let me know if there is anything else that I can do for you.
Best Answer10-28-2018 08:45
10-28-2018 08:45
Best Answer10-30-2018 12:44
10-30-2018 12:44
@Sheenak86 happy to hear that you were able to link both accounts following @LanuzaFitbit's instructions. Is your tracker syncing with your Fitbit app? Could you share a screenshot of your Fitbit app's Dashboard? Try revoking the Vitality's permissions from the Fitbit app on the website and relink them.
I look forward to your reply!
