Solved!
Linking my fitnesspal to FitBit
1 ACCEPTED SOLUTION
6 REPLIES 6
Solved!
Solution
Thanks for taking a break from stepping to visit the Comm...
Message contains a hyperlink
Cheers Edson. Have disconnected the two apps via the webp...
 Your time while following the recommended workarounds i...
Hi Edson No difference at all today. FitBit and MyFitness...
 Thanks for the update. You can find below the informati...
Message contains a hyperlink Message contains an image
Re:  Thanks for the update. You can find below the informati...
