04-26-2015 08:33
04-26-2015 08:33
Best Answer04-26-2015 20:40
04-26-2015 20:40
Pick a logging mechanism and use that one. Ideally, Fitbit should recognize the duplicate activities but if the times don't line up (e.g. MFP records by the minute while Fitbit tracks to the second I believe) then you'll get duplicate activities. You can always tracks via Fitbit and MFP but you should delete one of the activities in your log.
Best Answer04-26-2015 20:55
04-26-2015 20:55
I see.
Thank you very much!
Best Answer04-27-2015 21:31
04-27-2015 21:31
Now i am not logging my exercises on MFP, only from my tracker. There is another problem that I couldn't check my activities that logged from my fitbit charge HR on MFP....
is there any soultion for that?
Thank thank thank!
Best Answer04-28-2015 01:06
04-28-2015 01:06
MFP uses "Fitbit calorie adjustments" to account for differences in estimated calorie burns. You won't see actual activities from Fitbit. I really only use MFP as an intermediary between Runkeeper and Fitbit and for logging food.
