07-10-2017 06:17
07-10-2017 06:17
Hi
Had a read of other issues with MFP communicating with Fitbit and i've tried the disconnect and reconnect solution form both ends and each end separately, however no donut. the info seems to be showing on fitbit and the steps appear to be showing on MFP but not activities (walking running etc) any ideas? im assuming its an MFP issue not Fitbit as info is showing this end not that.
Best Answer07-10-2017 09:01
07-10-2017 09:01
Hi, @SunsetRunner! Do you mean mfp activities are not showing up on Fitbit? That is a one-way transfer, Fitbit does not send activities to mfp.
MakMak | Community Council
07-10-2017 09:01
Best Answer07-10-2017 09:20
07-10-2017 09:20
Thanks. I was speaking to them on twitter and sadly as you say there is no individual activity integration with mfp at the moment
