01-07-2017 04:44
01-07-2017 04:44
I restarted using MFP and it will not sync with Blaze, I revoke access in Fitbit, disconnect in MFP, delete apps and when I restart everyting, MFP comes up with the Surge on the Dashboard
Best Answer01-12-2017 12:32
01-12-2017 12:32
It's great to have you here @mmasters! Thank you so much for the troubleshooting that you've done.
I would like you to make sure that you unlinked both applications by following this instructions:
- Then log into your Fitbit account at www.fitbit.com, click the gear icon, then Settings, next click Applications, then Click the blue ‘Revoke Access’ button and revoke access for MyFitnessPal
- It’s important to make sure Fitbit has been disconnected on both MyFitnessPal and Fitbit
- Once disconnected, please wait 15 minutes then try to reconnect from the MyFitnessPal website
- Go back to www.MyFitnessPal.com website (not the Fitbit or MFP app) and relink your Fitbit device via the main Apps tab, here.
- Once you have reconnected, go back to the Apps tab online and make sure Fitbit is now showing on the right-hand side of the page under Your Apps
This should refresh your link on both sides. Once you have reestablished the connection, you need to then make sure to elect Fitbit as your step source.
You can elect Fitibit as your Step source either via the Menu in the App, then Steps. Or online here.
Hope this helps!
