10-19-2015 11:39 - edited 10-20-2015 11:31
We are aware that some users are seeing thousands of extra steps appearing on their account this morning. At this time, we believe the issue is caused by a third-party app called "LFconnect" by Life Fitness. This app is creating many erroneous activity logs, which result in the appearance of these extra steps.
At this time, we'd recommend disconnecting this app under the Applications tab of your Dashboard settings and manually removing the logs that appear on your Manual Logging page.
We are working with this partner to make sure the issue is resolved as quickly as possible, and will update this thread when we believe it to be working normally again.
10/20 Update: Life Fitness has acknowledged the issue with their integration, which is resulting in many extra steps. They have disabled the integration, so that no workout data should currently be transmitting to Fitbit accounts at this point. They plan to release a full fix by tomorrow, October 21st, after which normal integration behavior should resume.
10-19-2015 10:27
10-19-2015 10:27
I found a ton of invalid activities (over 40 of them) and I deleted them manually. Just need to keep an eye on ti.
Best Answer10-19-2015 10:29
10-19-2015 10:29
Best Answer10-19-2015 10:39
10-19-2015 10:39
Best Answer10-19-2015 10:43
10-19-2015 10:43
Best Answer10-19-2015 10:48
10-19-2015 10:48
Best Answer10-19-2015 10:54
10-19-2015 10:54
Best Answer10-19-2015 11:08
10-19-2015 11:08
Best Answer10-19-2015 11:09
10-19-2015 11:09
I encountered same problem with my Fitbit Surge and posted about it in a topic under the Surge Product. I am waiting for Fitbit Customer Support to call me back with their analysis. They took my cell number in the morning.
Best Answer10-19-2015 11:10
10-19-2015 11:10
Best Answer10-19-2015 11:12
10-19-2015 11:14
10-19-2015 11:14
Best Answer10-19-2015 11:15
10-19-2015 11:15
Best Answer10-19-2015 11:25
10-19-2015 11:25
I had 57,000 steps this morning when I woke up.
I contacted support and ask them to clear my dashboard.
I was told, no because the engineers are working on it.
I was in a challenge that I had to drop out of, I didn't think it was fair to have that many steps!
10-19-2015 11:25
Ihave just discovered this issue now. My Surge is currently showing 49k+ steps, when I should be around 6k. what is also confusing is that on Saturday and yesterday it registered the correct amount of steps at the time, but is now showing very elevated steps.
I wish I could get more than 50k steps in one day! I thought I was doing well on Sat getting over 20k (this is an accurate count). I'm not sure why it is retrospectively adding steps while I was resting 😕
10-19-2015 11:28
10-19-2015 11:28
Best Answer10-19-2015 11:31
10-19-2015 11:31
Mine did too! I am just now looking into getting it figured out!
Best Answer10-19-2015 11:32
10-19-2015 11:32
I believe several people have support tickets submitted and they (Fitbit) are looking into the issue. I'm charging my flex now to see if I have the same problem.
10-19-2015 11:34 - edited 10-19-2015 11:48
Holy c__p, by the sounds of it, you guys are all Olympians! I don't know what's going here, so hopefully a mod will chime in and enlight us all.
Cheers!
TW
Best Answer10-19-2015 11:36
10-19-2015 11:36
10-19-2015 11:36
10-19-2015 11:36
Hi!
Would love a solution to this problem! I had over 32000 steps when I woke up and my FitBit was just sitting on my dresser!!!
@DrMcKinzie wrote:
At approximately 8 am 10/19/15 both my wife's and my Fitbit one added 30,000 steps. Then we noticed that high numbers of steps had been retroactively added Friday, Saturday, and Sunday that were there prior to this morning. What is going on?
