08-25-2021
18:48
06:23
08-25-2021
18:48
06:23
I cant seem to get my fitness pal to show my fitbit data anymore. Can someo e please tell me how to fix this?
Best Answer09-01-2021 05:02
09-01-2021 05:02
Did you try login off and on again. I sometimes have to remove the Fitbit from the MFP acct and then add it again. If that doesn’t work I usually wait a day or two and it corrects itself.
Best Answer09-01-2021 09:59
09-01-2021 09:59
I have tried this loads. It finally syncs but the next day the same problem occurs again
Best Answer09-05-2021 11:34 - edited 09-05-2021 11:39
@SunsetRunner the only thing we can suggest is to revoke MFP'S access and link the accounts up.
If this fails, it is time to contact MFP. They are responsible for this link up.
Here is an answer that worked for one user.
I've moved your none Blaze question into the third party support.
