08-26-2015 17:36
08-26-2015 17:36
My exercise totals have remained consistent in level of steps and active minutes, but my My Fitness Pal app the last few days has been showing little to no additional calories added to my total for the day for exercising. My Fitness Pal has been no help in explaining why it would be showing me with a few hundred extra calories one day, but absolutely none (or a couple of dozen) the past several. Are there sync issues with the One or MFP that others are having? Any suggestions on how to make sure it's syncing properly or how to determine if the Fitbit says I've burned XXXX calories, how many MFP should have shown in my additional calories at the end of the day for comparison?
Thanks.
08-27-2015 07:43
08-27-2015 07:43
MFP registers the steps you are sending over. Are you getting the right number of steps?
Also, they both use the same BMR calculator, so you can check that to see your BMR (http://www.myfitnesspal.com/tools/bmr-calculator).
I also use MFP and haven't seen any issues, although the two didn't sync last night, so I had 2000+ steps in MFP instead of 10000+. I synced them this morning with no issue.
MakMak | Community Council
09-14-2015 04:20
09-14-2015 04:20
Hi @allsherote , I've had exactly the same problem over the last few days. I am fairly active throughtout the day and constantly on my feet/walking around throughtout the day. Over the last week or so although my activity level hasnt change the calorie adjustment on MFP has drastically reduced. Did you ever find an answer/resolution to your query?
Thanks
09-14-2015 04:28
09-14-2015 04:28
09-14-2015 05:10
09-14-2015 05:10
09-15-2015 08:01 - edited 09-15-2015 08:12
I also encountered a change in calorie counting.
You can find it here -https://community.fitbit.com/t5/Third-Party-Integrations/MFP-need-help-how-to-interpret-Fitbit-calor...
Is this problem somehow similar to yours?
Seems like MFP has stopped syncing manually added exercises back to Fitbit - last exercise synced "back" to Fitbit was a Kettlebellse exercise on Friday last week...
10-28-2015 12:19
10-28-2015 12:19
Hello Fitbitters! Did you already tried to unlink and relink the Fitbit and MFP accounts?
