02-05-2017 08:15
02-05-2017 08:15
Since last apple update my food log on my fintnees pal is not syncing with my fitbit app. Is this a know problem, is there a fix? cheers
Best Answer02-05-2017 11:17
02-05-2017 11:17
IPhone update should not have anything to do with it. It is internet linked accounts.
Try un- linking, close app, re-open, then re-link with correct user if and password.
Did you find my post helpful? Vote for it or mark it as a Solution!
02-05-2017 11:17
02-05-2017 11:17
02-07-2017 10:34
02-07-2017 10:34
worked - Thanks
Best Answer06-04-2019 12:10
06-04-2019 12:10
I've tried every suggestion on here, and now I think I need to move on. It used to work pretty well, only needed to run through one or more of these processes 2 to 3 times per week, but lately it became a daily, sometime several times per day, process, and now after a few hours of trying everything listed on this forum over and over, it seems like it's just not going to happen. I have a Fitbit Charge 2 that I bought about 2 months ago and a Google Pixel 2 that I bought in 2017.
Does anyone have any workarounds? I tried looking to see if I can at least enter steps manually into MFP, but to no avail.
Thanks!
Best Answer06-04-2019 13:42
06-04-2019 13:42
@BigBoomer85 there is currently a known issue and MFP is working on a resolution. Please see this thread.
As this is an older thread, I will be closing it for further reports.
Actively managing your weight? Find accountability buddies on the Manage Weight board
