08-20-2015 18:24
08-20-2015 18:24
08-20-2015 23:48
08-20-2015 23:48
This is automatic when the two accounts are linked. Are yours linked with no adjustment?
By default you only get positive calorie adjustments in MFP i.e. if you are more active than anticipated then fitbit sends MFP a positive calorie adjustment. If you are less active than expected then fitbit will not do anything. However, there is a setting within MyFitnessPal that lets fitbit send negative adjustments in these instances.
10-09-2015 17:42
