09-29-2014 19:03
09-29-2014 19:03
Best Answer10-01-2014 16:30
10-01-2014 16:30
Thanks for stopping by @Mo09! I recommend to try unlinking and relinking both account. You can follow the steps below:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
I hope this helps you out! ![]()
Best Answer10-03-2014 06:23
10-03-2014 06:23
Best Answer10-04-2014 15:09
10-04-2014 15:09
Hi @Pinkfruity! I suggest to contact MFP so they can investigate on this and help you figure out what other account you have with them.
I hope this gets resolved for you soon.![]()
