02-06-2017 05:52
02-06-2017 05:52
When I put that had 60oz of water in my fitness pal, it shows up as 59.95 oz on my Fitbit dashboard. Please help me understand what's going on.
02-07-2017 05:17
02-07-2017 05:17
Hello @afeag, good to see you again in our Fitbit Community. I believe this happens when the information transfers to your Fitbit account, some decimals are reduced from the total amount of water logged in MFP.
I replicated your scenario using my MFP and Fitbit account and something similar happened. In my case I logged 60oz in MFP and it was reflected on my Fitbit Dashboard 59.99oz.
As way to troubleshoot the integration between your accounts, I recommend to revoke the access of MFP from your Applications settings in your online-Dashboard and re-link one more time by going to MFP apps.
As a workaround, you can logged this information directly on your Fitbit Dashboard to avoid this discrepancies.
Hope this helps, let me know if you have more questions.
02-27-2017 13:55
02-27-2017 13:55
I am having the same problem when logging water into the MFP app. When it displays in the Fitbit app it has weird decimals. I saw the suggestion to log water using Fitbit, which I'm fine with but if we log water only in Fitbit will it sync *to* MFP (not just from)? I tried logging water on the Fitbit app but then it didn't show in the MFP app. Is it just that there's a delay or do I need to do something differently? Perhaps, this is a question for MFP but thought I would start here.
Also I did try disconnecting and reconnecting the two services. I'm hoping that will work also. 🙂
Thanks.
03-18-2017 06:37
03-18-2017 06:37
Hello @mythachite, good to see you again. When you logged water on MFP it will be transferred to Fitbit as I sugested before, however it wont work in the same way if you logged water in your Fitbit account, since this wont be share to MFP. So you re not seeing a delay at the moment to sync your information, also rest assure you are not doing anything differently.
See you around. Let me know if you have additional questions.
