01-17-2014 13:07
01-17-2014 13:07
Hello all, I have not been able to get my fitbit dashboard and myfitnesspal to sync today. I have tried disconnecting them and emptying my cache to no avail. Any help?
03-12-2014 16:44
03-12-2014 16:44
It's mid March and mine started having problems. I hope this gets fixed soon!
03-29-2014 08:17
03-29-2014 08:17
My problem is that I have to unlink and link the Fitbit everyday for the last month. It used to sync right away when I opened my computer but not now. I have to do it everyday and it's very annoying. I would like to know if I am the only one going through this. Is the problem on the side of Fitbit or Myfitnesspal? I have been using Fitbit for almost 2 years now and never had the problem before.
03-29-2014 08:28
03-29-2014 08:28
If you have he MFP app on your phone you can choose sync under menu and it will sync with the apps you have connected it with.
03-31-2014 15:22
03-31-2014 15:22
So I assume they are still having problems with the syncing?
I was looking at my calorie in vs calorie out on the dashboard for the last few days, ust checking my progress. On the fitbit dashboard it says I went over my calorie out which confused me because I was sure I was under on Saturday. I went back and checked and while MFP has a record of the exercise I did Saturday it was not transferred over to fitbit. So on MFP I was under my calories but fitbit thinks I am over because it lost my 500 caloties burned at step Saturday morning. Will this eventually correct itself or is that data lost. I ask because I rely on my weekly report to see how much weight I should have lost vs how much I actually lost. Although the weekly report has also been sporadic too. Fitbit needs to fix these issues:(
03-31-2014 17:22
03-31-2014 17:22
I have seen that option on my phone and it said that it syncs. Somehow. I still have to unlink and link every day and sometimes I even have to log out of myfitnessal and log back in again before it works. I had to do it today again. It is kind of frustrating cause it never did that until a month ago. Hope it gets fixed soon.
04-04-2014 10:00
04-04-2014 10:00
So once again Fitbit dashboard and MFP aren't syncing. I don't know if the issue is on Fitbit's side or My Fitness Pal, but this is getting pretty annoying. It was working fine for a few weeks, and now, nothing. Exercise doesn't go to MFP, and MFP foods don't go to the dashboard. So annoyed.
04-06-2014 14:31
04-06-2014 14:31
Well log on to what was fairly good harmony of products in September, now need to loose some weight after totally going off the rails and the two dont want to talk.
Unsynced about 6 times today on various platforms: mac, ipad, iphone.
Had to double log everything which will cause more of a headache later but needed to keep track.
Day one weight: unimpressed with this
06-11-2014 23:36
06-11-2014 23:36
I have chosen today to get "back on the bandwagon" with my food, after using my force for the last couple of months. No syncing for me either. I unlinked the accounts yesterday (before reading this thread) as was a while since I used MFP. It synced the food I had put on over to Fitbit. But I then removed the food (was just to check it all etc) and today it is still showing on Fitbit. And breakfast has't synced either so am guessing I am going to be having issues. Unfortunatly as I live in the UK, the Fitbit food log is no good hence using MFP
09-17-2014 01:27
09-17-2014 01:27
09-19-2014 15:57
09-19-2014 15:57
09-19-2014 20:40 - edited 09-19-2014 20:41
Start here -> https://www.fitbit.com/apps/myfitnesspal
09-19-2014 20:47
09-19-2014 20:47
Hey Chris!!
Thanks for the reply. I meant sync the Myfitnesspal app to the Health app from the new Apple IOS8
09-19-2014 20:55
09-19-2014 20:55
I have not updated to iOS 8 yet.
Waiting for everyone else to test it for me.
I don't think the integration is there yet.
However, that would be a question for myfitnesspal.com support or Apple Support Communties.
09-19-2014 21:17
09-19-2014 21:17
thanks I only ask bc someone in this string said that they did it successfully.. thanks for your quick responses though!
09-19-2014 21:49
09-19-2014 21:49
09-20-2014 01:04
09-20-2014 01:04
You could do it from the myfitnesspal app for a couple of days however as of yesterday they removed that option at the request of Apple so it's no longer available. There's a bug in the Health app which Apple are working to fix. Should be ready by the end of September and I imagine all of the fitness apps will then add it back in.
09-20-2014 01:23
09-20-2014 01:23
09-20-2014 01:33
09-20-2014 01:33
@RickA wrote:
How do you achieve that? I cannot get Health App to connect with anything nor can I find it in Settings
You can't anymore. Apple have removed the option because of a bug - see my previous post. It effects every fitness and tracking app on the app store.
01-04-2015 16:45
01-04-2015 16:45
Everytime I try to connect it, it takes me to a button that says connect. Then wants me to open the mfp app. I don't know if they have connected, but it appears not since my food intake on my fitbit app says 0 calories intake. I am beginning to get extremely frustrated. Is there a cs where I can speak to a person?
