06-04-2019 11:29 - edited 06-11-2019 10:59
UPDATE 06/11/2019
Hello everyone!
Thank you all for sharing your details and experiences with MFP.
I'd like to share some wording on the latest update posted by MFP. You can click here to see their full statement.
"It's possible you have an expired access token. This means that the authentication between MyFitnessPal and Fitbit has expired, and you need to re-authenticate using your Fitbit credentials for sync to resume. This is not directly related to this incident, but is a top reason why some members do not see data sync. However, it should be easy to fix if you follow the exact steps outlined below. Once re-authenticated, sync will resume from the date of relink forward; Past data will not sync.
I hope you find this useful. Let us know if there are any other questions on the matter.
_________________________________________________________________________________________
UPDATE 06/06/19:
Hello everyone.
As it has been mentioned and shared already, the issue appears to have been resolved by MFP already and now they are waiting for the backlog of sync requests to be completed.
You can read about it by clicking here.
Thank you all for your patience.
Hello everyone!
We'd like to let you all know that we are aware of a syncing issue between Fitbit and MyFitnessPal (MFP) that has been going on since June 3rd. MFP is aware of this and they are investigating the issue. You can see what they have to say about the whole situation by clicking here.
Below you can see an extract of what MFP has said:
"Our team continues to investigate to isolate the root cause of the issue. At this time some users will see no data syncing, while some may see some data syncing sporadically. We are working on resolving this for all members."
For the time being we do not recommend disconnecting and reconnecting the apps. We recommend waiting for MFP to identify a solution.
We'll keep you all updated on this as it develops.
Remember to vote for posts that helped you out! Tired of the same workout music? Try a Podcast! 🙂
08-18-2017 09:34
08-18-2017 09:34
I have not been able to get my fitness pal and fit bit to sync despite trying all the suggestions.
08-18-2017 17:49
08-18-2017 17:49
08-18-2017 17:49
08-18-2017 17:49
08-20-2017 01:27
08-20-2017 01:27
@Elisebeth at what step does it fail?
@Ghu have you both followed the instructions.
08-20-2017 17:57
08-20-2017 17:57
I finally got mine to start working again. Not sure what repaired it except just revoking everything twice. It just started working again seemingly as accidentally as it failed. I even thought some of the pixels were going out on it after the syncing came back, but after charging it, everything was okay all day today. Hope it stays that way. Thanks for the guidance, everyone!
10-17-2017 13:45
10-17-2017 13:45
I did this.. I revoked access to MFP by going through the website in the links in your post, and now it's no longer in the list and I don't see how to get the access back to MyFitnessPal and MyFitnessPal is still not showing the steps from FitBit.
12-01-2017 02:00
12-01-2017 02:00
You have to disconnect my fitness pal and fit bit on an actual PC or Laptop. If you do it from your phone it will NOT work. Also once you do this on your PC or Laptop, please try switch of your mobile phone and restarting before linking the accounts again. It works when you use this approach. Only glitch however is that it wont take in to account exercise days or calories burned for an already closed diary. Hope this helps.
12-01-2017 04:59 - edited 12-01-2017 05:01
@charliDMB you need to reconnect by going to MFP or using their app.
You can go to www.fitbit.com//apps this will direct to to the right page on MFP
02-02-2018 16:08
02-02-2018 16:08
my fitness pal once revoked doesn't show up. how do I add it back
02-02-2018 16:27
02-02-2018 16:27
Go to the link in my last post. Find MFP, tap it and on the next page there will be instructions.
07-20-2018 12:45
07-20-2018 12:45
I revoked access, but don't know how to get myFitnessPal back in.
07-20-2018 13:46
07-20-2018 13:46
You need to log into your MFP account, then go to the page setup by MFP to link up with Fitbit.
I would look at the help pages on MFP .
06-03-2019 20:06
06-03-2019 20:06
You like me have made it worse. Myfitnesspal is down, just wait.
https://myfitnesspal.desk.com/customer/en/portal/articles/2976520-fitbit-sync-issues
06-03-2019 20:25
06-03-2019 20:25
MyFitnessPal stopped tracking my steps randomly in the middle of the day. I've browsed the forums and have tried to disconnect the apps SEVERAL times and nothing is working. I really rely on these methods to track my calories. Is there any other way to fix this.
Note: my Fitbit model is the Versa
06-03-2019 22:44
06-03-2019 22:44
I'm having the exact same issue! and I've tried all the things and I can't get MFP to sync with Fitbit. I don't understand what I'm doing wrong.
06-03-2019 22:48
06-03-2019 22:48
This happened to me right after lunch 😞 I have tried unlinking and then linking again from both apps but nothing works.
06-04-2019 01:29
06-04-2019 01:29
Hi @ges813, @Howwrdj7287 and @maliadrennan. Nice to see you in the community.
There appears to be a known issue with the Fitbit - Myfitnesspal sync (see here). You are advised not to try to relink your Fitbit and myfitnesspal accounts as this causes extra load on the server. If you keep an eye on the link I posted above, it should be updated with the progress of the fix.
I understand the frustration though as I too rely heavily on Myfitnesspal for food logging. Hopefully a fix won't be too far away.
06-04-2019 05:57
06-04-2019 05:57
Maybe they should have sent a push notification to those of us that have the MyFitnessPal app on our phone. Then we might have been a little more patient. So annoying.
06-04-2019 10:09
06-04-2019 10:09
I seem to be having the same issue, but it was working fine yesterday and stopped syncing this morning. Its so frustrating. Do you have an update on a fix? As like the others I have followed the suggested steps in the forums of disconnecting the apps, logging out and reconnecting but nothing is working so far.
Help!
