06-04-2019 11:29 - edited 06-11-2019 10:59
UPDATE 06/11/2019
Hello everyone!
Thank you all for sharing your details and experiences with MFP.
I'd like to share some wording on the latest update posted by MFP. You can click here to see their full statement.
"It's possible you have an expired access token. This means that the authentication between MyFitnessPal and Fitbit has expired, and you need to re-authenticate using your Fitbit credentials for sync to resume. This is not directly related to this incident, but is a top reason why some members do not see data sync. However, it should be easy to fix if you follow the exact steps outlined below. Once re-authenticated, sync will resume from the date of relink forward; Past data will not sync.
I hope you find this useful. Let us know if there are any other questions on the matter.
_________________________________________________________________________________________
UPDATE 06/06/19:
Hello everyone.
As it has been mentioned and shared already, the issue appears to have been resolved by MFP already and now they are waiting for the backlog of sync requests to be completed.
You can read about it by clicking here.
Thank you all for your patience.
Hello everyone!
We'd like to let you all know that we are aware of a syncing issue between Fitbit and MyFitnessPal (MFP) that has been going on since June 3rd. MFP is aware of this and they are investigating the issue. You can see what they have to say about the whole situation by clicking here.
Below you can see an extract of what MFP has said:
"Our team continues to investigate to isolate the root cause of the issue. At this time some users will see no data syncing, while some may see some data syncing sporadically. We are working on resolving this for all members."
For the time being we do not recommend disconnecting and reconnecting the apps. We recommend waiting for MFP to identify a solution.
We'll keep you all updated on this as it develops.
Remember to vote for posts that helped you out! Tired of the same workout music? Try a Podcast! 🙂
Best Answer06-05-2019 13:07
06-05-2019 13:07
I'm having the exact same problem. Already unlinked and relinked the apps from pc and mobile, and nothing seems to work. It's a nightmare!
Best Answer06-05-2019 13:10
06-05-2019 13:10
Thanks Tony R. Much appreciated. Didn't realise how much I relied on it until now! 🙂
@Tony.r wrote:The MFP server is currently down so it's just a case of waiting patiently until it's back online and up and running again. It's worth keeping an eye on the the MFP Website for further updates from their tech team.
Best Answer06-05-2019 13:15 - edited 06-05-2019 13:16
I made the mistake of logging out of my Android app a while ago and can't now log back in again. I thought I'd just try and sign in to my account on the Web which I was able to do, but just to confirm nothing has synced for me today in either direction.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer06-05-2019 14:17
06-05-2019 14:17
I'm sure we all have read the June 3rd update and understand that this is a known issue that is being looked into.
Best Answer06-05-2019 15:05
06-05-2019 15:05
Thank you so much for letting us know...it is driving me crazy! 🙂
Best Answer06-05-2019 16:02
06-05-2019 16:02
Mine is not syncing fitness pal, water intake, active hrs.. I've done all the usual: cleared cache, uninstalled app, restarted Bluetooth, phone reboot, logged out etc. Only thing I'm unable to do is force close, the app won't let me. Any suggestions?
Best Answer06-05-2019 17:02
06-05-2019 17:02
Let's go to the third party board, where the main thread is on this subject and read the OP.
about this being a know issue that is being looked into.
I'm going to merge this thread into the main thread so that you will get updates.
Best Answer06-05-2019 17:21
06-05-2019 17:21
This is getting ridiculous. I haven’t been able to sync anything for three days.
Best Answer06-05-2019 18:26
06-05-2019 18:26
Also, I can't get continuous sync, or pushed sync between Fit Bit and Weight Watchers. WILL update, if I remove FB from WW, and re-link, one time only.
Best Answer06-05-2019 19:57
06-05-2019 19:57
Yes we are aware that WW also has an unrelated problem. MFP says that the problem is on their end.
Best Answer06-05-2019 20:43
06-05-2019 20:43
Do you have an ETA of when the issue will be resolved? There should be a notice from your app that says this in an email versus us fumbling around and thinking that it is just something wrong with our device. In addition, I had a food entry replicated 60 TIMES (said I ate 60 pieces of toast) when I just had 1 in the app that I entered. If this is not a reliable app I may have to try another one.
Best Answer06-06-2019 00:36
06-06-2019 00:36
Yesterday l had the same problem, calories showed 8,000 for the day!! It had added on 1slice of bread about 50 times...had to flipping delete them all
Best Answer06-06-2019 03:01
06-06-2019 03:01
All official updates will be found at the top of this thread @Cleo55. since you are subscribed you will get notifications
Best Answer06-06-2019 03:29
06-06-2019 03:29
I notice that the posts here have slowed/stopped. Also, food logged in MFP is showing in my fitbit log this morning and I have yet to see the entry duplication in MFP. Could it be fixed?
Best Answer06-06-2019 04:35
06-06-2019 04:35
Ok now it is Thursday and the 3rd day of not syncing. I also have no access to the mfp community so I can’t see what had been posted there. Can somebody please let me know what is happening? I do not see any updates for this issue.
Best Answer06-06-2019 04:38
06-06-2019 04:38
Tap here for the latest update on MFP. You can refresh that page occasionally to stay up to date on the situation.
On a side note, the WW app is working again.
05:37
09:25
06-06-2019
05:37
09:25
Hello everyone.
Please know that MFP is aware of the situation and they are investigating on it. As soon as they have found a solution, or have corrected the issue, we will be updating this thread to reflect that.
Thanks for your understanding and patience on the situation.
06-06-2019 06:00
06-06-2019 06:00
Best Answer06-06-2019 06:05
06-06-2019 06:05
Thanks for the updates. I am mostly posting this to continue to see updates. I have the same bug where it’s not counting my steps and it’s multiplying my food by crazy numbers.
Best Answer06-06-2019 07:12
06-06-2019 07:12
For info from MFP see
@KiminiiCricket. a simple subscribe found under options would get notifications.
