04-07-2015 06:22
04-07-2015 06:22
Hi,
I am using MyFitnessPal in conjuntion with my Charge HR. I am entering all my food into MyFitnessPal and using the Charge HR to record my step related exercise, etc.
After entering food into MyFitnessPal and having the negative calorie adjustment turned on for the Charge Hr in MyFitnessPal, the calories left for the day do not match between MyFitnessPal and the Fitbit app.
Which reading should I be looking at for Calories left? MFP? or the Fitbit app? Or should I be turning the negative calories setting to Off?
I would think these two totals should be pretty much in line, correct?
Best Answer04-09-2015 13:53
04-09-2015 13:53
@benna12 It's nice to have you on board! Yes, you're right both MFP and Fitbit should give you the same amount of calories eaten. Negative Adjustments shouldn't be enabled if you don't sync your tracker during the day or if you don't consistently use your Fitbit tracker. You can learn more about the calorie adjustment by checking this article.
Additionally, you can try to disable negative adjustments and unlink and relink both accounts.
P.S. I apologize for the delayed reply.
