10-21-2015 12:42 - edited 10-29-2015 11:12
Fitbit Update 10/29/2015: As this issue has now been resolved, I am closing the thread from further discussion.
Thank you to everyone who reported this issue and for your patience while we worked to get it resolved. Happy to know that your food logs are back to normal! ![]()
Fitbit Update 10/25/2015
Syncing food from MFP to Fitbit is now back to normal. Thank you again for everybody's patience while this problem was being worked out.
Fitbit Update 10/22/2015: MyFitnessPal is aware and has added this to their known issues page. Fitbit and MyFitnessPal are closely working together to get this issue resolved ASAP.
In the meantime, a workaround to try is to manually delete the duplicate entries from your Fitbit Food Log. In order to delete duplicate entries, do the following:
Another option is to unlink your MyFitnessPal account from your Fitbit account and checking your calories on MFP until the multiplying issue is fully resolved!
Thank you for your continued patience as we work alongside MFP to get this issue resolved!
Fitbit Update 10/21/2015: Some users have reported that their MyFitnessPal food log entries are being multiplied on their Fitbit Food Log.
Sorry for the inconvenience, but Fitbit and MyFitnessPal are both aware of the issue. We are currently working on resolving this issue with MFP's help. MyFitnessPal has also posted an update here as well. I will share updates here with everyone when I find out more! Thank you for your patience! ![]()
10-22-2015 22:11
10-22-2015 22:11
my calorie count is wrong - it says i have over eaten on FITBIT but myfitnesspal says differnt - the past 2 days have been playing up - i have a iphone
please help
@Jcross wrote:
Thanks. I have tried this, and it worked once, but went back to the wrong
count quickly after
Best Answer10-22-2015 22:15
10-22-2015 22:15
Best Answer10-22-2015 22:44
10-22-2015 22:44
Best Answer10-22-2015 23:13
10-22-2015 23:13
My fitbit is doing the samething. When I post my food its doubleing my calories.
Best Answer10-22-2015 23:40
10-22-2015 23:40
Best Answer10-23-2015 02:16
10-23-2015 02:16
10-23-2015 02:58
10-23-2015 02:58
This IS a big deal. I rely on the interface of these apps to make may health/activity/dietary goals achievable. I want to spend my valuable free time achieving these goals, not correcting data entry errors that have been introduced.
10-23-2015 03:08
10-23-2015 03:08
Best Answer10-23-2015 03:24 - edited 10-23-2015 03:26
You must really busy, if you can't fit the two minutes per day, to correct the entries, into your schedule, but I understand that's an extra 20 calories you could have been burning or two minutes off your recovery sleep. Just think, if you hadn't made that post or read any of the previous posts, you could have done the adjustments several times over.
Best Answer10-23-2015 03:25
10-23-2015 03:25
Best Answer10-23-2015 03:32
10-23-2015 03:32
Trust me, I didn't waste time reading a bzillion posts. Letting MFP and FB know client concerns is my goal, and that's how I spent that 30 seconds. Those 2 "extra" minutes? Those are for my family. Lose the snark and join the team!
10-23-2015 03:48
10-23-2015 03:48
Best Answer10-23-2015 04:07
10-23-2015 04:07
Best Answer10-23-2015 04:09
10-23-2015 04:09
Sorry, can't help the snark, it's just one of the many facets of my winning personality. I just think people should take a more positive approach to, what I agree, is not an ideal situation. I'm sure Fitbit and MFP will have it resolved fairly soon, until then you have a choice of spending that little extra time editing the data, leaving it recording incorrectly, saving some time by not recording your data or spending extra time looking for alternative means of recording it. There are probably other options I haven't considered, but I just wanted to save you a little time by giving you some options.
Best Answer10-23-2015 04:20
10-23-2015 04:20
Best Answer10-23-2015 04:26
10-23-2015 04:26
MFP bug fix out this morning. I've installed and it appears to have handled the issue.
Best Answer10-23-2015 04:41
10-23-2015 04:41
Glad I am not the only one! I am going to ignore the bogus fitbit calculations and just continue logging on MFP and hopefully, Fitbit will figure it out!
10-23-2015 04:48
10-23-2015 04:48
Best Answer10-23-2015 04:50
10-23-2015 04:50
10-23-2015 05:03
10-23-2015 05:03
