04-17-2017 10:59 - edited 04-17-2017 12:16
MyFitnessPal is aware of an issue with its Fitbit integration. You can read more here.
Until this issue is resolved, you can expect these two platforms to not sync with one another. We will update this thread when they resolve this issue.
04-17-2017 06:01
04-17-2017 06:01
Same. My fitbit has not reported steps to MFP in 2 days either....
04-17-2017 06:19
04-17-2017 06:19
MyFitnessPal is not syncing my steps with Fitbit. I have a Charge 2 which was recently automatically updated with firmware version 22.22.53.4.
I have found that if I disconnect my Charge 2 from my MFP account, revoke MFP access via my Fitbit account, wait 15 minutes, and then reconnect my tracker and renew fitbit access to MFP, then I can get my steps to show up in my diary. However, they won't accumulate. Each time I want to see my current step calculation in my MFP diary, I have to go back through the whole manual linking/relinking process to get the steps to populate in my MFP account. This is a pain! MFP is saying that the issue is with Fitbit's firmware. Please fix.
Best Answer04-17-2017 06:32
04-17-2017 06:32
I am also having the same problem I have done everything each post has told me to do, unlinking each app logging out of them and also I have tried doing that while deleting and reinstalling the apps
Best Answer04-17-2017 06:39
04-17-2017 06:39
My steps from fitbit charge 2 are also not syncing with MFP. This started on April 16, 2017 for me and a number of days after updating to the new firmware. I would like answers too....
Best Answer04-17-2017 06:40
04-17-2017 06:40
Same issue for me too!!! Help!
Best Answer04-17-2017 07:35
04-17-2017 07:35
I have the exact same problem. I hope someone wakes up soon to get it fixed.
Best Answer04-17-2017 07:46
04-17-2017 07:46
Same here updated to the new firmware and haven't had a step sync from my fitbit since Saturday 15th April though everything else seems to be syncing and info added into MFP is syncing back to Fitbit..I have tried to force sync, disconnect etc and not luck. Nice to see its to just me.
Best Answer04-17-2017 07:48
04-17-2017 07:48
Same here, MFP is sending to Fitbit, but calorie adjustment isn't happening. Getting hungry!. Perhaps MFP will sort problem soon.
04-17-2017 08:01
04-17-2017 08:01
I'm in the same boat... last 2 days. Guess I'll switch it to letting my iPhone reading steps for now
Best Answer04-17-2017 08:07
04-17-2017 08:07
Glad I'm not alone. This happened when I first syced my Charge 2 with MPG then it corrected itself after a few days. Hopefully that will happen again because this is annoying!
Best Answer04-17-2017 08:14
04-17-2017 08:14
Same here was working great one day(sat) then the next day after it had upgraded its software i have to keep disconnecting/reconnecting to get any joy!!!!!
Best Answer04-17-2017 08:46
04-17-2017 08:46
I am having the same problem.
Best Answer04-17-2017 09:07
04-17-2017 09:07
Best Answer04-17-2017 09:12
04-17-2017 09:12
Best Answer04-17-2017 09:23
04-17-2017 09:23
I am having the same issue on the same days. Not syncing between Fitbit Charge 2 & MFP. Any solution?
Best Answer04-17-2017 09:25
04-17-2017 09:25
@JEha wrote:Fitbit and MFP are not syncing steps. Everything is coming through (calories, exercise entries in MFP)....but the steps are not coming into MFP. I even revoked the connection and reattached and still nothing changed with the steps. In MFP...I see it say updating on the home screen and then it comes back still as 0 steps. I'm not sure which end the problem is occurring on...MFP or Fitbit so mentioning in both help forums so hopefully someone can figure out what's happening. For me, this started yesterday (4/16) and continues today.
04-17-2017 09:25
I have the same problem since yesterday and I have to delete the fitbit from my apps on the myfitnesspal website and then to add it again. It does not help much though, because next time I want to sync the data, it would work again. Very annoying!
Best Answer04-17-2017 09:29
04-17-2017 09:29
I had the same problem yesterday. I could only resolved this issue by deleting myfitness pal App and reinstalling it again. Works good now.
Best Answer04-17-2017 09:39
04-17-2017 09:39
I reported this to MFP yesterday, and have received several emails telling me they are aware and working on the problem on their end. They also suggested that we notify Fitbit and make sure it's not anything on that end as well.
Best Answer04-17-2017 09:42
04-17-2017 09:42
Fitbit has an update too, but my problem started before I applied the update.
