Hi,
I started using MFP yesterday with Fitbit.
MFP is taking my activity and making adjustments properly. However, Fitbit isn't logging my food from MFP properly.
Yesterday, I logged all meals on MFP, including a number of snacks. All that shows up in Fitbit is dinner; none of the other stuff has made it across.
This morning, I logged breakfast and a snack on MFP. The snack has appeared in MFP but not breakfast.
I understand that Fitbit will only take the kcals and nutrients etc from the MFP database; however, it only seems to be taking the odd meal here and there.
Is there a particular way I should log the food in MFP to make it all show up?
Thanks,
Nick
Best AnswerYou are not doing anything wrong and it is not clear where the problem lies. Suggest that you try disconnecting and then reconnecting the apps.
Best AnswerThanks for that advice.
It seems to have just started working now before I saw your reply but thanks all the same.
Nick
