01-01-2017 11:58
01-01-2017 11:58
As of 12/27/2016, my Charge HR and MyFitnessPal are not sharing data. I'm looking for help in this matter. I don't see my food diary entries in the Fitbit mobile app and no exercise calories posting to MyFitnessPal.
01-01-2017 12:40
01-01-2017 12:40
im having the same problem, jsut trying a few things now
01-01-2017 12:57
01-01-2017 12:57
Same problem.... frustrating! Not sure what else to try. (Charge 2)
01-01-2017 14:34
01-01-2017 14:34
I tried disconnecting the two apps and reconnecting - nothing seems to work.
01-01-2017 14:38
01-01-2017 14:38
PS - I'm not new to this - the connection has been working for a year and a half. Will a moderator please respond to this?
01-01-2017 17:43
01-01-2017 17:43
I'm having the same problem. I just got a new iphone 7 and My fitness pal will not sync at all. I've been able to sync on the old iPhone 5s and my iPad for two years but since the new phone was set up the iPad will no longer sync.
01-01-2017 17:46
01-01-2017 17:46
I'm having the same problem. I just got a new iphone 7 and My fitness pal will not sync at all. I've been able to sync on the old iPhone 5s and my iPad for two years but since the new phone was set up even the iPad will no longer sync.
01-01-2017 17:46
01-01-2017 17:46
I've had my iPhone 7 Plus for a month and a half with no problem, this just started on 12/27. Looking for a solution!
01-01-2017 17:53
01-01-2017 17:53
I'm following as well.
When I log into MFP, Fitbit is not listed as connected, however, when I attempt to connect MFP gives a message saying a different Fitbit account is linked to MFP which cannot be. I cannot see anywhere in Fitbit that it show apps that may be connected. I do receive weight updates from my Fitbit aria. MFP also receives weight updates via Fitbit. What I don't see is food calories consumed and logged into MFP coming over to Fitbit and I don't get exercise calories from Fitbit coming over to MFP. I am unable to flag Fitbit as the source in MFP for step counting as it is not on the list.
01-01-2017 17:59
01-01-2017 17:59
Mine even shows as connected!!!! Other than that, the situation is the same. Calories consumed not showing on Fitbit, exercise not showing in MyFitnessPal...
01-01-2017 18:11
01-01-2017 18:11
Same here. It worked fine for years, but I just tried again after two months off and there's nothing. It shows 0 Fitbit steps on my diary page for both the OS app and on myfitnesspal's webpage.
01-01-2017 18:37
01-01-2017 18:37
I have figured how to revoke access from the fit bit app. But when I try to connect the result is the same. Same message stating another account is already linked but no actually connection.
01-03-2017 05:38
01-03-2017 05:38
yeah o revoked access , deleted both apps, even deleted my account. and tried again. still no thing. not been working since the filmware update tbh
01-03-2017 20:39
01-03-2017 20:39
Same problem here with the Fitbit One. Mine has been working/syncing for 4 years without issue, but now hasn't synced since 12/21. I tried contacting MFP but have yet to get a response. I'm starting to look for new calorie trackers that will sync with Fitbit!
01-04-2017 04:17
01-04-2017 04:17
last night i tried logging out of my fitness pal and logging out of my fitbit app on the phone, when i logged back in it was working 🙂 try it
01-04-2017 05:45
01-04-2017 05:45
I'm having the same problem with my Flex.
This is the 1st time in 3 yrs I've had this issue. I've tried all the same steps to fix it, with no luck.I hope they find the fix soon.
01-05-2017 02:52
01-05-2017 02:52
Same here! Thank you for posting guys, I though I was doing something wrong. I thing this is VERY IMPORTANT to us all and it should be solved. I do not want to enter my food intakes twice: Fitbit should import this from myFitnessPal. And the latter import the activity from fitbit, not just the estimation of calories spenditure, but my footsteps and the rest of exercices
01-05-2017 08:56
01-05-2017 08:56
Same here. For me food log is going from MFP to Fitbit, but the steps are not going from Fitbit to MFP.
01-05-2017 10:22
01-05-2017 10:22
01-05-2017 15:39
01-05-2017 15:39
I finally got mine to work yesterday! I'm not sure which, if any, of the below helped in the matter, but here's what I did:
Removed both apps from my secondary device (iPad)
Logged in and back out of both sites on my computer
In MFP, under "more", clicked on "steps" and changed it from Fitbit Tracker to iPhone (also selected "don't track steps" at one point).
I disconnected Fitbit under More/Apps & Devices (disconnecting one will disconnect both the scale, which I don't have, and the tracker)
Once i saw that it was accepting steps from my phone, I reconnected Fitbit and switched Steps back to Fitbit Tracker and it worked!
Good luck to you
