@Roseyy Welcome to the Community! Thanks for the troubleshoot you've done. MyFitnessPal was having some issues with syncing data. You may want to check the latest update posted here. Check this great post to see if your apps are properly connected posted by @AndrewFitbit.
If after doing this, you're still not getting the information synced; please contact MFP directly so they can further investigate it.
Hope this helps.
