07-15-2018
23:10
09:19
LanuzaFitbit
07-15-2018
23:10
09:19
LanuzaFitbit
Hello. Ive had a fitbit for 5 days and love it already.
Ive not been able to connect to my fitness pal for about 12 hours. I tried to reconnect by revoking access within the fitbit dashboard. Now i cant reconnect.
Can anyone help get them linked?
Within Myfitnesspal it says its atill connected but selecting disconnect does nothing. Within fitbit if i select myfitness pal it takes me to open the app.
I dont want to start logging in fitbit as could end up with duplicate data when they connect together again.
Thanks loads for any help x
07-19-2018 09:12
07-19-2018 09:12
Hello @waggledance! Welcome to the Forums!
Thank for bringing this up.
It is possible that for some reason they are both stuck. I'd recommend that you try to log out of both ends and then setup the connection again. That should force everything to reload and then they might connect properly. Please give it a try and see how it goes.
Let me know if there are any further questions.
