02-15-2016 14:02
02-15-2016 14:02
When using Map My Walk and my fitbit Charge at the same time, the GPS device and the fitbit are over a mile apart with the Charge reading, say six miles, and Map My Walk indicating 4.8 miles. Should I reset the charge?
Best Answer02-17-2016 03:58
02-17-2016 03:58
It's great to have you here @fit2Btied222! I'm happy to hear you are using Fitbit with Map My Walk.
In regard to your question, I believe that restarting the tracker can help improve your tracker's performance, however, I suggest you also setup a stride length on your Dashboard in case you haven't done it. Click on this article to follow instructions on how to do it.
Give this a try and let me know if you see any improvement on your readings.
Best Answer02-20-2016 14:55
02-20-2016 14:55
Best Answer02-22-2016 03:36
02-22-2016 03:36
Fantastic news @fit2Btied222! I'm very happy to hear this and to know that you are now back on track with matching data.
Keep up the good work! Let me know if you have any other questions. ![]()
