It's great to see you around @Amyflex. If your Fitbit account is not syncing with your MFP account, I recommend relinking the account by doing the following:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
Let me know the outcome. ![]()
