11-18-2014 19:35
11-18-2014 19:35
Best Answer11-20-2014 05:43
11-20-2014 05:43
@KAFerrie Tahnks for joining this Community Family! In order to fix your issue.please try to unlink and relink both Fitbit account and MyFitnesspal account. How? Please follow the steps below:
1. Go to your Fitbit Dashboard, click the gear icon in the upper right corner, select "Settings" from the drop-down meny, click on "Applications" on the left side of your screen and clik on "Revoke Access" option under MyFitnessPal.
2. Re-link the two accounts by going to the app. Click here.
Give it a try and let me know how it works!
Best Answer11-24-2014 09:41
11-24-2014 09:41
@KAFerrie Hope you're doing well, and enjoying some healthy activities! I noticed that @EdgarFitbit has offered a suggestion to help resolve your issue with Fitbit not syncing with MFP. Was that the information you were looking for? If so, I invite you to mark @EdgarFitbit post as the solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions here.
If this didn't resolve your question, or you're still unclear on Fitbit syncing to MFP, let me know and I'll be happy to work through it with you.
