Just want to confirm what I think I understand, with the exception of the default SMS, Phone and Calendar apps on Android, you can't add programs to receive notifications from? For example, on my Gear Fit, I can add programs and get notifications from them, or delect them and not. But basically any app that send notifications to the bar on top passes to the Gear Fit.
No good on Fitbit?
Thanks
@Pigknuckle Welcome to the Community! You won't get notifications from all the apps that you have in your phone. Depending in the tracker that you have, you'll get the following notifications:
Fitbit Alta Call, text and calendar
Fitbit Blaze
Fitbit Surge Call and text
Fitbit Charge
Fitbit Charge HR Call
Fitbit Force
You can vote for this idea in case you want to get more notifications in your tracker.
Thanks for voting.
@PR51 It's great to have you here! Thanks for your feedback. That for sure will be a plus to the Fitbit Charge HR. We recommend users to vote for the ideas that are already in our Ideas Board because those ideas are viewed by our engineers and developers and the best of this is that people can vote for them.
Those ideas completely help our engineers to create new features in our trackers and Dashboard. Whenever the idea has been implemented or it's under consideration, the status of the suggestion will change to reflect the change.
Thanks for your understanding.
