03-30-2019
10:09
06:45
LanuzaFitbit
03-30-2019
10:09
06:45
LanuzaFitbit
Had my Fitbit for 3 days I’ve synchronised it with my nutracheck app and last 2 days it’s transferred calories steps etc but today it won’t do any of that, is there a issue? Thanks for any help
Moderator edit: Label and Clarified subject
Best Answer03-30-2019 16:45
03-30-2019 16:45
@KezzaB76 Welcome to the forum! Have you tried revoking the Nutracheck access in the application settings on Fitbit.com and then linking/connecting both accounts again?
03-30-2019 16:45
Best Answer04-02-2019 06:44
04-02-2019 06:44
Welcome to the Forums @KezzaB76. Hello @Marrrmaduke.
I apologize for the delay in my response. @Marrrmaduke Thanks for being around to help!
@KezzaB76 As mentioned above, please do try to disconnect the two apps and connect them again. This should help so that the integration starts working properly again and you should start getting the information from Nutracheck.
Keep us posted on how it goes or if you have any further questions.
Best Answer06-19-2019 02:21
06-19-2019 02:21
I've revoked access - what do I do next?! Please help - Fitbit and Nutracheck have always synced, but haven't done so now since May 20th!
Best Answer06-20-2019 12:36
06-20-2019 12:36
Welcome to the Forums @Eeyore1970.
Thanks for trying what was recommended in here.
Since you have already revoked the access now please connect both of the apps once more. You can do so by going into the Nutracheck app. After they reconnect the apps should start syncing from that point forward. Do note that the information that has not synced since May 20th will not be syncing retroactively.
Let me know if there are any other questions I can help you with.
Best Answer06-25-2019 07:09
06-25-2019 07:09
Best Answer06-27-2019 06:50
06-27-2019 06:50
Hello @Eeyore1970.
Thank you very much for sharing those details and letting me know that it is working now.
It is possible that a sync request was sent back then and thus after being able to reconnect the two, the request went through and all that data moved between the apps. I am happy to know that you are back on track.
If you have the time, perhaps you could visit one of our Discussion boards. Lots of different topics to talk about with other users on the Forums.
Please let me know if there is anything else that I can help out with.
