07-31-2022 10:40
07-31-2022 10:40
I use a Fitbit Luxe with the Fitbit and PAI apps. PAI Health was bought by Zepp which makes Amazfit devices. Zepp is removing the PAI app and it will only support other devices. PAI is based on an algorithm that differentiates activity by beats per minute and awards more PAI points towards maintaining a minimum weekly PAI of 100 for time working out at higher heart rate zones. These zones are personalized based on age, resting heart rate and other factors. PAI provides a simplified metric to maintain cardiovascular health at any age and is based on research. Does a Fitbit have a way to track PAI now that PAI Health app support for non-Amazfit devices has been removed?
07-31-2022 10:46
07-31-2022 10:46
That similar approach was built into the Active Zone Minutes based on recommendations from CDC and American Heart Association (I think), giving double minutes for higher heart rates.
Best Answer07-31-2022 10:51
07-31-2022 10:51
Best Answer07-31-2022 11:19 - edited 07-31-2022 11:23
Hello @PAIappuser and welcome to the Community. Fitbit doesn't track PAI, but almost every heart rate enabled Fitbit can be used to track PAI in its app. You can see the list here: Which devices are supported? Tap on your PAI Health app avatar > Devices > then follow the steps to link your Fitbit. If you switch from one Fitbit to another, the change is seamless on the PAI app. I've switched among the Versa 3, Charge 5, and Luxe and my PAI app just kept on tracking.
Fitbit and PAI take different approaches to tracking activity. Fitbit follows the CDC recommendations for moderate and vigorous physical activity. PAI awards points for lower intensity activity not counted by Fitbit.
Laurie | Maryland
Best Answer07-31-2022 14:27
07-31-2022 14:27
08-01-2022 03:46
08-01-2022 03:46
@PAIappuser I never got that email. Interesting.
Laurie | Maryland
08-01-2022 05:30
08-01-2022 05:30
I did get that email a while ago. I still had the app, though I had stopped using it a while ago. I had been a big fan of the approach when I first read of it years ago, and research that supposedly backed up their claim of heart health benefits, and the tracker that first used it (can't remember the brand name). Then the tracker went out of business, but continued as a stand-alone app. Unfortunately, it all relied on getting accurate heart rate readings, which was not always possible.
Best Answer08-01-2022 05:35
08-01-2022 05:35
07-30-2023 02:16
07-30-2023 02:16
I used PAI on a Mi Band- I can say that it was an excellent addition to motivate you to increase your heartrate and keep your fitness levels high. The current fitbit "zone minutes" is not even close to the value of PAI index for me. Unfortunately, in Australia there is not Fitbit interface with the PAI app which has been removed from the market. I would be very interested if the FItbit developers would investigate this metric - it is really, really helpful, motivating and has good evidence in mortality benefit
https://www.ntnu.edu/cerg/personal-activity-intelligence
It can be accessed via the Memento U app in USA and Norway only. I am still hoping that we will get a release as it was really fun to use.
07-30-2023 16:23
07-30-2023 16:23
