Possible to exclude steps data synchronisation to Endomondo
ANSWERED
Hey,
I want to have most the data from the Fitbit app in Endomondo, but the step count just seems like a lot of data to include and a lot of irrelevant data to have in Endomondo. I just think it should be a possiblity to exclude some of the data instead of having all transferred.
Is it possible? I have looked several times and have never found a solution for this.
Thank you for your help.
1 BEST ANSWER
Accepted Solutions
Hi there @boetk. Welcome to the Community Forums!
I'd like to know what data are you specifically you are referring to about the step count. For the third party apps, it's basically them who decide what data to include on their reports/dashboards or whatever way they will display the stats so I'd recommend getting in touch with Endomondo for them to take a look at your request directly.
Hope I helped here and if this is not exactly what you were asking or if there is anything else you may need, I'm here to help! 🙂
Ferdin | Community Moderator, Fitbit
4 REPLIES 4
Hi did you manage to stop this, as I have the same problem.
Thanks
No I just found out that it is actually the only thing which will synchronize and not all the exercises that you have from Fitbit. I just stopped the synch since it was more annoying than helpful.
Gutted. .it was one of the reasons I bought it
