12-18-2017 11:37 - edited 12-19-2017 09:18
Fitbit Update 12/19/2017: This issue is now resolved and you should be able to successfully sync your Fitbit/MFP accounts once again.
I am closing this thread but if the issue pops back up, I ask that you please create a new thread and reference this for a description of the issue. Thank you for your reports and continued patience.
Fitbit Update 12/18/2017: Some MyFitnessPal users have reported that they're experiencing issues with syncing their Fitbit information over to MFP.
MyFitnessPal is aware of this issue and working to resolve it as quickly as possible. Please follow their article for updates here. I will also make sure to keep this thread updated with any new information.
12-18-2017 08:02
12-18-2017 08:02
Lol. Well it sure doesn’t seem like they’re in much of a hurry. I spent 45 minutes trying to fix this last night before I logged into their FAQ forum and found out that they were down. My guess is that it has something to do with the recent IOS update. Regardless.....super frustrating!!!
12-18-2017 08:06
12-18-2017 08:06
I also have the same issue. I've read the posts to disconnect and resync. I've tried every variation via app and browser and I just can't get steps to sync up into MFP anymore as of Sunday. Very anxious to get this back, I'm 20 pounds down and having Fitbit and MFP connecting is an integral part of my weight loss program. Thanks.
12-18-2017 08:07
12-18-2017 08:07
Since the last update to both the Fitbit app and the Samsung Galaxy 7, Fitbit and MyFitnessPal aren't syncing. I have disconnected and reconnected the devices with no luck. Is this a new known bug... again? It seems like I always have problems every time something updates.
12-18-2017 08:19
12-18-2017 08:19
Hi, I also am having this exact problem. I disconnected the apps on the computer, deleted both the apps on my phone, then after 1/2 hour, reconnected the apps on computer and reinstalled the apps but no luck. Issue started on the 17th Dec also. Following to see if there is another solution!
12-18-2017 08:33 - edited 12-18-2017 08:36
Same issue here since 12/17. Steps not syncing in MFP and food logged not syncing in Fitbit. Hoping for a solution!!
12-18-2017 08:38
12-18-2017 08:38
This is an issue in the last couple of days for me too. I’m glad to see you’re aware of it. At least I know it’s a server communication issue and not something specific to my devices.
12-18-2017 08:45
12-18-2017 08:49
12-18-2017 08:49
Thanks for that info!
12-18-2017 08:49
12-18-2017 08:49
MFP website indicates they have a problem that started yesterday and has not been resolved.
12-18-2017 08:52 - edited 12-18-2017 08:54
Hi, I also have the same issue since 17/12. Food log on MFP did not sync to Fitbit. I disconnect and reconnect few times but still having the same issue. I have the same issue at the beginning of this month. But after revoking the access to MFP and reconnect again, everything go back to normal. Really hope someone can help here... 😞
12-18-2017 08:53
12-18-2017 08:53
Thanks!
12-18-2017 08:54
12-18-2017 08:54
Okay, that's good news that it's something MFP is working on. Do you have a link? Thanks!
12-18-2017 09:10
12-18-2017 09:10
Same! I’ve tried everything.
12-18-2017 09:37
12-18-2017 09:37
It seems this is an MFP problem. There was an outage last night and they are working to fix it.
12-18-2017 09:54
12-18-2017 09:54
Having the same problem and tried all the same solutions with no success. I not sure if last night's outage is really the source of the problem. I have not been able to synch for two days. I'm more inclined to think a recent update of MFP (12/15) is the source of the issue. Interested to see what MFP's solution will be.
12-18-2017 10:10
12-18-2017 10:10
I haven't had this functionality since I went from a Charge to a Charge 2.
Might I just need to go through the merry dance of uninstallation, revoking access etc?
12-18-2017 10:28
12-18-2017 10:28
Ditto, I had done the same then I saw someone post a link to that article/page on these forums.
They have these issues every few months and it usually drives me back to logging food in fitbit. I haven't done that yet since I have been using the MFP Recipes feature a lot lately and fitbit doesn't have the same functionality AFAICT. And every time I do move back to fitbit for logging food I hate the limited food database, but at least I can manually enter the proper nutrition info if I have it.
12-18-2017 10:33
12-18-2017 10:33
having same problem...just started yeasreday (12/17/17). Tried disconnect/reconnect as well as steps suggested by myfitnesspal (most recent hep I found from them was from ladt January). Nothing worked. Even went so far as to uninstall and reinstall both apps. Still no success. Very dissapointing. My guess is there's a communication issue between your app and theirs. Using Samsung S7, but have the same problem on my Fire tablet...which was previously working just fine as well.
12-18-2017 10:35
12-18-2017 10:35
Been having the same issue since yesterday. Last sync was around 12:30 am Sunday. Hasn’t connected since.
12-18-2017 10:48
12-18-2017 10:48
Same for me over the last couple of days
