04-02-2018 09:47 - edited 04-09-2018 09:21
Fitbit Update 04/09/2018: MyFitnessPal has completed their scheduled maintenance. If you're still experiencing issues, I recommend reaching out to MyFitnessPal Support.
I am closing this thread as the scheduled maintenance has been completed. Thanks for your patience.
Fitbit Update 03/30/2018: Hi everyone -- Starting in the afternoon of Fri, 3/30, MyFitnessPal started some scheduled maintenance with the Fitbit integration, which may have caused an interruption in service.
There has been a delay in the completion of their maintenance until this week. Thanks for your patience.
Best Answer04-09-2018 07:50 - edited 04-09-2018 08:06
Hi there @Mary438 and @Helen66. Thank you for letting us know you are experiencing the same issue and for the additional feedback.
According to MyFitnessPal, the scheduled maintenance has been completed and syncing should be resume by now.
If the issue persists, please try to reconnect your accounts to refresh the integration between MFP and Fitbit. For more help, the following post will serve you as a reference.
Otherwise, for more assistance refer to MyFitnessPal Customer Support.
See you around until the next opportunity.
