05-25-2025 11:46
05-25-2025 11:46
There doesn't seem to be a resolution for this. Fitbit says check with Renpho and Renpho says check with Fitbit. Both apps are showing as connected but the weight does not update in Fitbit. It used to with just dinner until I was forced to sign in Fitbit with my Google account, so I suspect the issue lies there. Does anyone have a solution for this? I have tried all the suggestions --close both apps, reinstall, disconnect and reconnect. Nothing!
05-25-2025 11:48
05-25-2025 11:48
*it used to work just fine until being forced to login with Google.
05-26-2025 08:42
05-26-2025 08:42
I am having the same issue. It started May 21st. I've deleted apps and reinstalled. Restarted devices. Toggled Fitbit on and off in renpho app. I emailed renpho but haven't heard back yet.
05-27-2025 09:03
05-27-2025 09:03
Hi. I have the same issue. My Renpho scales stopped syncing about a week ago. Renpho indicated an issue with Fitbit servers. Tried revoking access then connecting a couple of times and reinstalling apps. Also, stress score now seems to have stopped recording too.
Best Answer05-27-2025 09:17
05-27-2025 09:17
It's affecting all 3rd party scales, not just Renpho. The team is aware of the issue.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
05-27-2025 09:31
05-27-2025 09:31
Thanks. I assume it will need an app update, any idea when?
Best Answer05-27-2025 10:50
05-27-2025 10:50
It's probably a server side fix, not and app update.
No idea when it will be fixed.
05-27-2025 11:05
05-27-2025 11:05
Renpho emailed me back and said it should be fixed with the update they are rolling out in phases. The update is 6.18.1, if I remember correctly
05-28-2025 04:58
05-28-2025 04:58
My scale synched this morning, no data for last 7 days though.
Best Answer05-28-2025 05:14
05-28-2025 05:14
Same here.
Best Answer05-28-2025 06:16
05-28-2025 06:16
Same with me this morning.
05-28-2025 07:27
05-28-2025 07:27
Mine hasn't yet. I did have a Fitbit app update this morning but not the Renpho one yet.
Best Answer05-29-2025 01:40
05-29-2025 01:40
It started around the same time for me, too (May 20th).
GOOD NEWS: As of today, it started syncing again! I guess they worked out the glitch! Thank you!
05-29-2025 01:56
05-29-2025 01:56
Did you get the Renpho 16.8.1 app update? I haven't had that yet and still not syncing.
Best Answer05-29-2025 04:21
05-29-2025 04:21
Mine did not update yet. Still 6.17.1. It synced again today.
Best Answer05-29-2025 04:27
05-29-2025 04:27
It was a Fitbit issue, not Renpho. All 3rd party scales were affected.
My scale started syncing yesterday and it synced again today.
05-29-2025 05:33
05-29-2025 05:33
Oh right. Mi e at that version but still not syncing and logging manually in Fitbit.
Best Answer05-29-2025 05:33
05-29-2025 05:33
Mine still not syncing.
