06-17-2018 15:05 - edited 06-19-2018 09:53
Update 6/19/2018: My Fitness Pal has reported this issue resolved as of yesterday. Thanks for your reports. If you are still experiencing issues, try unlinking the connection from both sides (Fitbit and MFP) then link the accounts again.
Update 6/17/2018: We are aware of issues with the My Fitness Pal and Fitbit integration. My Fitness Pal is currently investigating, you can follow their progress here. We will also update this thread as we here further. Thanks for your reports.
Actively managing your weight? Find accountability buddies on the Manage Weight board
Best Answer06-17-2018 15:16
06-17-2018 17:35
06-17-2018 17:35
Thank you Kate. I was getting worried.
06-18-2018 10:25
06-18-2018 10:25
Good to know it’s not just me!
06-19-2018 09:53
06-19-2018 09:53
Update 6/19/2018: My Fitness Pal has reported this issue resolved as of yesterday. Thanks for your reports. If you are still experiencing issues, try unlinking the connection from both sides (Fitbit and MFP) then link the accounts again. I'll be closing this thread for further comments.
